Introducción
This guide is for replacing the printhead carriage on your HP Officejet Pro 6835 or 6830. Be sure to remove ink cartridges before attempting replacement. Check out the Troubleshooting Page to ensure replacement is the right option.
Qué necesitas
Open the main lid as far as it will go.
Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
Open the lid further.
Herramienta utilizada en este paso:Tweezers$4.99
Using the tweezers, remove the right side of the metal clamp that is holding the metal frame in place by pulling up.
With the tweezers, unhook the metal coil side of the clamp and pull up to remove it completely.
Repeat these steps on the other side of the printer.
Una persona más ha completado esta guía.
