Qué necesitas
Pull on the two tabs on the back of the printer to release the left side cover.
Remove the cover by rotating it towards the front of the printer.
With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
Lift the cover off of the printer.
Remove 2 screws on the back of the printer, one on the left, and one on the front.
Remove one cable from the top of the laser assembly and one cable from the right side of the laser assembly.
Remove 4 screws from the laser assembly.
Remove all cables from the cable clip on the side of the laser assembly and remove it from the printer.
