Saltar al contenido principal
HP LaserJet 1160 or 1320 Duplexer PCB Replacement
Qué necesitas
  1. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Left Side Cover: paso 1, imagen 1 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Left Side Cover: paso 1, imagen 2 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Left Side Cover: paso 1, imagen 3 de 3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Right Side Cover: paso 2, imagen 1 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Right Side Cover: paso 2, imagen 2 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Right Side Cover: paso 2, imagen 3 de 3
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Back Cover: paso 3, imagen 1 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Back Cover: paso 3, imagen 2 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Back Cover: paso 3, imagen 3 de 3
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: paso 4, imagen 1 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: paso 4, imagen 2 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: paso 4, imagen 3 de 3
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: paso 5, imagen 1 de 1
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan: paso 6, imagen 1 de 2 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan: paso 6, imagen 2 de 2
    • Disconnect the fan cable from the main board of the printer.
    • Remove the retaining clip holding the fan in.
    • Remove the 2 screws holding the fan in.
  7. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan Cable: paso 7, imagen 1 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan Cable: paso 7, imagen 2 de 3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan Cable: paso 7, imagen 3 de 3
    • Remove the fan cable from the cable guide.
  8. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Duplexer PCB: paso 8, imagen 1 de 2 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Duplexer PCB: paso 8, imagen 2 de 2
    • Disconnect one cable from the main board of the printer.
    • Disconnect the duplexer solenoid cable from the duplexer PCB.
    • Remove one screw on the duplexer PCB and remove the PCB from the printer.
Conclusión
Una persona más ha completado esta guía.
jdp23
Miembro Desde 08/22/13
1,302 Reputación
23 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 405
