Saltar al contenido principal
HP Envy x360 15m-bp111dx Battery Replacement
Qué necesitas
  1. HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: paso 1, imagen 1 de 2 HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Battery Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bp111dx Battery Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bp111dx Battery Replacement: paso 2, imagen 3 de 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Battery Replacement, Battery: paso 3, imagen 1 de 2 HP Envy x360 15m-bp111dx Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Battery Replacement: paso 4, imagen 1 de 3 HP Envy x360 15m-bp111dx Battery Replacement: paso 4, imagen 2 de 3 HP Envy x360 15m-bp111dx Battery Replacement: paso 4, imagen 3 de 3
    • Carefully lift the battery, and pull it towards you to remove it.
Conclusión
Una persona más ha completado esta guía.
Tori Luongo
Miembro Desde 02/22/22
268 Reputación
2 Guías creadas
Equipo
Clemson, Team 2-2, Hunter Spring 2022 Miembro de Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Miembros
6 Guías creadas
Un comentario
This website has been very helpful but you only show how to remove a battery. You've left out the replace part of the replacement. Would really help. Thanks!
book mite - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 828
