Saltar al contenido principal
HP Envy 4520 Lid Backing Replacement
  1. HP Envy 4520 Lid Backing Replacement, Lid Backing: paso 1, imagen 1 de 1
    • Grab hold of the front and back of the left side of the lid backing.
    • Face the printer towards you and push the lip of the lid back towards the lid hinges.
    • You may need to apply a lot of pressure to the lid. You will hear two clicks when the hinge releases.
  2. HP Envy 4520 Lid Backing Replacement: paso 2, imagen 1 de 2 HP Envy 4520 Lid Backing Replacement: paso 2, imagen 2 de 2
    • Lay the lid with the white backing facing up with the lip of the lid facing your body.
    • Peel the white backing away gently.
    • There will be a layer of foam glued to the bottom of the white lid backing.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 792
