Saltar al contenido principal
HP Elitebook x360 1040 G5 Battery Replacement
Qué necesitas
  1. HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: paso 1, imagen 1 de 2 HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: paso 1, imagen 2 de 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Battery Replacement: paso 2, imagen 1 de 2 HP Elitebook x360 1040 G5 Battery Replacement: paso 2, imagen 2 de 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Battery Replacement, Battery: paso 3, imagen 1 de 2 HP Elitebook x360 1040 G5 Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Battery Replacement: paso 4, imagen 1 de 3 HP Elitebook x360 1040 G5 Battery Replacement: paso 4, imagen 2 de 3 HP Elitebook x360 1040 G5 Battery Replacement: paso 4, imagen 3 de 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
Conclusión
Una persona más ha completado esta guía.
Corey Agena
Miembro Desde 04/21/19
794 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S1-G4, Maness Spring 2019 Miembro de Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 46
Todo El Tiempo: 2,149
