Introducción
Use this guide if you are experiencing difficulty with your battery, especially if your laptop is over five years old. If the battery does not fully charge or your computer only turns on when plugged in, it may be time to replace your battery. This guide provides detailed instructions to replace your laptop’s battery.
Qué necesitas
Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
Una persona más ha completado esta guía.
