Saltar al contenido principal
HP Elitebook x360 1030 G2 Battery Replacement
Qué necesitas
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: paso 2, imagen 1 de 2 HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: paso 2, imagen 2 de 2
    • Remove the five Torx-4 T4M2.0×7.4 shoulder screws that secure the bottom cover to the computer.
    • Use a spudger to separate the rear edge of the bottom cover and the keyboard/top cover.
    • Remove the bottom cover by sliding it up and back at an angle.
  2. HP Elitebook x360 1030 G2 Battery Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the system board.
    • Remove the six Phillips PM2.0×5.3 screws that secure the battery to the keyboard/top cover.
    • Remove the battery.
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
Max Kletskov
Miembro Desde 04/22/20
40,307 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,908 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 27
Ultimos 30 días: 111
Todo El Tiempo: 4,288
