Saltar al contenido principal
HP EliteBook x360 830 G7 Solid State Drive Replacement
Qué necesitas
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: paso 1, imagen 1 de 2 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: paso 1, imagen 2 de 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: paso 2, imagen 1 de 1
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: paso 3, imagen 1 de 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: paso 3, imagen 2 de 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: paso 3, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: paso 4, imagen 1 de 1
    • Gently pull the SSD free from the M.2 socket.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 34
Ultimos 30 días: 81
Todo El Tiempo: 1,561
