Saltar al contenido principal
HP EliteBook x360 830 G6 Cooling System Replacement
Qué necesitas
  1. HP EliteBook x360 830 G6 Cooling System Replacement, Unfasten the back cover: paso 1, imagen 1 de 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: paso 2, imagen 1 de 2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: paso 2, imagen 2 de 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: paso 3, imagen 1 de 2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: paso 3, imagen 2 de 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: paso 4, imagen 1 de 3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: paso 4, imagen 2 de 3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: paso 4, imagen 3 de 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: paso 5, imagen 1 de 3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: paso 5, imagen 2 de 3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: paso 5, imagen 3 de 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: paso 6, imagen 1 de 3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: paso 6, imagen 2 de 3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: paso 6, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  7. HP EliteBook x360 830 G6 Cooling System Replacement: paso 7, imagen 1 de 3 HP EliteBook x360 830 G6 Cooling System Replacement: paso 7, imagen 2 de 3 HP EliteBook x360 830 G6 Cooling System Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  8. HP EliteBook x360 830 G6 Cooling System Replacement: paso 8, imagen 1 de 1
    • Separate the fan and cooling system from the motherboard.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Bukari
Miembro Desde 09/01/21
97 Reputación
1 Guía escrita
Equipo
Gateway, Team 1-2, Saknee Fall 2021 Miembro de Gateway, Team 1-2, Saknee Fall 2021
GCC-SAKNEE-F21S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 44
Todo El Tiempo: 581
