Saltar al contenido principal
HP EliteBook 8560w CD/DVD ROM Replacement
Qué necesitas
  1. HP EliteBook 8560w CD/DVD ROM Replacement, Battery: paso 1, imagen 1 de 2 HP EliteBook 8560w CD/DVD ROM Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w CD/DVD ROM Replacement: paso 2, imagen 1 de 1
    • Pull the battery out.
  3. HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: paso 3, imagen 1 de 2 HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: paso 3, imagen 2 de 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w CD/DVD ROM Replacement: paso 4, imagen 1 de 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: paso 5, imagen 1 de 2 HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: paso 5, imagen 2 de 2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w CD/DVD ROM Replacement: paso 6, imagen 1 de 3 HP EliteBook 8560w CD/DVD ROM Replacement: paso 6, imagen 2 de 3 HP EliteBook 8560w CD/DVD ROM Replacement: paso 6, imagen 3 de 3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w CD/DVD ROM Replacement: paso 7, imagen 1 de 2 HP EliteBook 8560w CD/DVD ROM Replacement: paso 7, imagen 2 de 2
    • Pull out the CD/DVD ROM with your hand.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 580
