Saltar al contenido principal
HP EliteBook 850 G3 WiFi Card Replacement
Qué necesitas
  1. HP EliteBook 850 G3 WiFi Card Replacement, WiFi Card: paso 1, imagen 1 de 1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 WiFi Card Replacement: paso 2, imagen 1 de 2 HP EliteBook 850 G3 WiFi Card Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 WiFi Card Replacement: paso 3, imagen 1 de 2 HP EliteBook 850 G3 WiFi Card Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 WiFi Card Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 WiFi Card Replacement: paso 5, imagen 1 de 2 HP EliteBook 850 G3 WiFi Card Replacement: paso 5, imagen 2 de 2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 WiFi Card Replacement: paso 6, imagen 1 de 3 HP EliteBook 850 G3 WiFi Card Replacement: paso 6, imagen 2 de 3 HP EliteBook 850 G3 WiFi Card Replacement: paso 6, imagen 3 de 3
    • Disconnect the coaxial cables wires from the WiFi card.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Miembros
6 Guías creadas
Un comentario
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
MV9000 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 1,594
