Saltar al contenido principal
HP EliteBook 850 G3 Motherboard Replacement
Qué necesitas
  1. HP EliteBook 850 G3 Motherboard Replacement, WiFi Card: paso 1, imagen 1 de 1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 Motherboard Replacement: paso 2, imagen 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Motherboard Replacement: paso 3, imagen 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 Motherboard Replacement: paso 5, imagen 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: paso 5, imagen 2 de 2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 Motherboard Replacement: paso 6, imagen 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 6, imagen 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 6, imagen 3 de 3
    • Disconnect the coaxial cables wires from the WiFi card.
  7. HP EliteBook 850 G3 Motherboard Replacement, Fan: paso 7, imagen 1 de 1
    • Gently unclip the plastic frame.
  8. HP EliteBook 850 G3 Motherboard Replacement: paso 8, imagen 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 8, imagen 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 8, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  9. HP EliteBook 850 G3 Motherboard Replacement: paso 9, imagen 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: paso 9, imagen 2 de 2
    • Carefully remove the connector for the fan.
  10. HP EliteBook 850 G3 Motherboard Replacement: paso 10, imagen 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 10, imagen 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 10, imagen 3 de 3
    • Carefully remove the fan and heatsink assembly from the laptop.
    • Slide out RAM (not pictured).
  11. HP EliteBook 850 G3 Motherboard Replacement: paso 12, imagen 1 de 1
    • Use a #00 Phillips screwdriver to remove twelve 5.7 mm screws from the motherboard.
  12. HP EliteBook 850 G3 Motherboard Replacement: paso 13, imagen 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 13, imagen 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 13, imagen 3 de 3
    • Remove the wire connectors.
  13. HP EliteBook 850 G3 Motherboard Replacement: paso 14, imagen 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: paso 14, imagen 2 de 2
    • Jiggle the motherboard until the ports (ie. headphone jack) come out from the sides and you can lift it up.
  14. HP EliteBook 850 G3 Motherboard Replacement: paso 15, imagen 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 15, imagen 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 15, imagen 3 de 3
    • Disconnect the wires underneath.
  15. HP EliteBook 850 G3 Motherboard Replacement: paso 16, imagen 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 16, imagen 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: paso 16, imagen 3 de 3
    • Take out the motherboard.
Conclusión
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 48
Todo El Tiempo: 3,432
