Saltar al contenido principal
HP EliteBook 850 G3 Fan Replacement
Qué necesitas
  1. HP EliteBook 850 G3 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: paso 2, imagen 1 de 2 HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Fan Replacement: paso 3, imagen 1 de 2 HP EliteBook 850 G3 Fan Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: paso 4, imagen 1 de 2 HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: paso 4, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Fan Replacement, Lift the battery: paso 5, imagen 1 de 3 HP EliteBook 850 G3 Fan Replacement, Lift the battery: paso 5, imagen 2 de 3 HP EliteBook 850 G3 Fan Replacement, Lift the battery: paso 5, imagen 3 de 3
    • Lift and pull the flap located at the top of the battery to remove it.
  6. HP EliteBook 850 G3 Fan Replacement, Fan: paso 6, imagen 1 de 1
    • Gently unclip the plastic frame.
  7. HP EliteBook 850 G3 Fan Replacement: paso 7, imagen 1 de 3 HP EliteBook 850 G3 Fan Replacement: paso 7, imagen 2 de 3 HP EliteBook 850 G3 Fan Replacement: paso 7, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  8. HP EliteBook 850 G3 Fan Replacement: paso 8, imagen 1 de 2 HP EliteBook 850 G3 Fan Replacement: paso 8, imagen 2 de 2
    • Carefully remove the connector for the fan.
  9. HP EliteBook 850 G3 Fan Replacement: paso 9, imagen 1 de 3 HP EliteBook 850 G3 Fan Replacement: paso 9, imagen 2 de 3 HP EliteBook 850 G3 Fan Replacement: paso 9, imagen 3 de 3
    • Carefully remove the fan and heatsink assembly from the laptop.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 46
Todo El Tiempo: 2,514
