Saltar al contenido principal
HP EliteBook 850 G3 Battery Replacement
Qué necesitas
  1. HP EliteBook 850 G3 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: paso 2, imagen 1 de 2 HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Battery Replacement: paso 3, imagen 1 de 2 HP EliteBook 850 G3 Battery Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: paso 4, imagen 1 de 2 HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: paso 4, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Battery Replacement, Lift the battery: paso 5, imagen 1 de 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: paso 5, imagen 2 de 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: paso 5, imagen 3 de 3
    • Lift and pull the flap located at the top of the battery to remove it.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Miembros
6 Guías creadas
2 comentarios
Thank you very much for this guide.
Geoff Taylor - Contestar
When charging the charging indicator remain orange for hours and does not change.
Raymond Malken - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 105
Todo El Tiempo: 9,478
