Introducción
The optical drive is responsible for reading optical disks such as CD’s or Blu-Ray disks. It is located on the side of the computer and pops out by a button that is also on the side of the computer
Optical drives could stop working for several reasons. Assuming your disk is not scratched, the problems could be narrowed down to corrupt driver, out of date firmware, or a factory defect. This guide will help you in the removal process of the drive to further diagnose the problem at hand.
Before starting, you will need to remove the battery, service cover, and the smart card reader.
Qué necesitas
Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
With the laptop latch still facing away from you, slide the left release latch to the left.
Position the laptop upside down with the optical drive facing toward you.
