Saltar al contenido principal
HP EliteBook 1050 G1 SSD Replacement
Qué necesitas
  1. HP EliteBook 1050 G1 SSD Replacement, SSD: paso 1, imagen 1 de 2 HP EliteBook 1050 G1 SSD Replacement, SSD: paso 1, imagen 2 de 2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 SSD Replacement: paso 2, imagen 1 de 1
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
  3. HP EliteBook 1050 G1 SSD Replacement: paso 3, imagen 1 de 2 HP EliteBook 1050 G1 SSD Replacement: paso 3, imagen 2 de 2
    • With the screws removed, the SSD should pop up off of the board below.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
    • When re-inserting the new SSDs make sure the white specs labels are facing up.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 525
