Saltar al contenido principal
HP EliteBook 1050 G1 RAM Replacement
Qué necesitas
  1. HP EliteBook 1050 G1 RAM Replacement, RAM: paso 1, imagen 1 de 2 HP EliteBook 1050 G1 RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Lift open the back panel with a Jimmy.
  2. HP EliteBook 1050 G1 RAM Replacement: paso 2, imagen 1 de 3 HP EliteBook 1050 G1 RAM Replacement: paso 2, imagen 2 de 3 HP EliteBook 1050 G1 RAM Replacement: paso 2, imagen 3 de 3
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 336
