Saltar al contenido principal
HP Chromebook CB2L Battery Replacement
Qué necesitas
  1. HP Chromebook CB2L Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Chromebook CB2L Battery Replacement, Battery: paso 1, imagen 2 de 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Battery Replacement: paso 2, imagen 1 de 3 HP Chromebook CB2L Battery Replacement: paso 2, imagen 2 de 3 HP Chromebook CB2L Battery Replacement: paso 2, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Battery Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Battery Replacement: paso 4, imagen 1 de 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Battery Replacement: paso 5, imagen 1 de 1
    • Using the plastic opening tool remove the battery from the Chromebook.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team S2-G6, Lacy Spring 2017 Miembro de USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Miembros
4 Guías creadas
2 comentarios
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - Contestar
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,420
