Introducción
If you are having trouble with your USB ports or motherboard in your HP Chromebook 14-q029wm trying connect it to your input and you have already tried to restart your computer, then following the steps provided might help you solve this issue. For more trouble shooting advice click here. This guide will show you how to replace the USB port/motherboard and get your computer working as new.
Qué necesitas
Remove nine 5mm Phillips #0 screws from the back case.
Remove the rubber caps using a spudger.
Remove the four remaining 5mm Phillips #0 screws.
Once the bottom is completely unclipped, remove the covering slowly so you do not pull and rip the wires.
There is a little black lever that you have to pull in order to remove the wires. They are found on top of where the wires are connected.
Remove the larger wire first.
Then remove the smaller wire.
From there the keyboard should completely come off.
Use your fingers to pull the white tab out of the black slot above the battery.
Una persona más ha completado esta guía.
