Introducción
In this guide, it will outline the process to effectively and safely replace the heat sink inside of a HP Chromebook without damaging the computer itself.
Qué necesitas
You will need a pair of tweezers and a Phillips screwdriver.
Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
Remove the heat sink from the laptop.
Una persona más ha completado esta guía.
