Saltar al contenido principal
HP Chromebook 11A G6 EE Keyboard Replacement
Qué necesitas
  1. HP Chromebook 11A G6 EE Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 HP Chromebook 11A G6 EE Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 HP Chromebook 11A G6 EE Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Keyboard Replacement: paso 2, imagen 1 de 3 HP Chromebook 11A G6 EE Keyboard Replacement: paso 2, imagen 2 de 3 HP Chromebook 11A G6 EE Keyboard Replacement: paso 2, imagen 3 de 3
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Keyboard Replacement: paso 3, imagen 1 de 2 HP Chromebook 11A G6 EE Keyboard Replacement: paso 3, imagen 2 de 2
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
Conclusión
William S
Miembro Desde 09/25/22
575 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 264
