Saltar al contenido principal
HP Chromebook 11 G8 EE Battery Replacement
Qué necesitas
  1. HP Chromebook 11 G8 EE Battery Replacement, Keyboard & Touchpad Assembly: paso 1, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Battery Replacement: paso 2, imagen 1 de 2 HP Chromebook 11 G8 EE Battery Replacement: paso 2, imagen 2 de 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Battery Replacement: paso 3, imagen 1 de 3 HP Chromebook 11 G8 EE Battery Replacement: paso 3, imagen 2 de 3 HP Chromebook 11 G8 EE Battery Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  5. HP Chromebook 11 G8 EE Battery Replacement: paso 5, imagen 1 de 3 HP Chromebook 11 G8 EE Battery Replacement: paso 5, imagen 2 de 3 HP Chromebook 11 G8 EE Battery Replacement: paso 5, imagen 3 de 3
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  6. HP Chromebook 11 G8 EE Battery Replacement: paso 6, imagen 1 de 2 HP Chromebook 11 G8 EE Battery Replacement: paso 6, imagen 2 de 2
    • Carefully lift the battery up and out.
Conclusión
Julia Latura
Miembro Desde 10/25/22
328 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 20
Ultimos 30 días: 70
Todo El Tiempo: 687
