Saltar al contenido principal
HP 7 Plus 1302 Power and Volume Button Replacement
Qué necesitas
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: paso 2, imagen 1 de 2 HP 7 Plus 1302 Power and Volume Button Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: paso 3, imagen 1 de 2 HP 7 Plus 1302 Power and Volume Button Replacement: paso 3, imagen 2 de 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: paso 4, imagen 1 de 1
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: paso 5, imagen 1 de 2 HP 7 Plus 1302 Power and Volume Button Replacement: paso 5, imagen 2 de 2
    • Pop out the power and volume buttons with your hands
Conclusión
Shannon Suttles
Miembro Desde 01/29/17
225 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-4, Baechle Spring 2017 Miembro de IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 261
