Saltar al contenido principal
HP 7 Plus 1302 Camera Replacement
Qué necesitas
  1. HP 7 Plus 1302 Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Camera Replacement: paso 2, imagen 1 de 2 HP 7 Plus 1302 Camera Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Camera Replacement: paso 3, imagen 1 de 2 HP 7 Plus 1302 Camera Replacement: paso 3, imagen 2 de 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Camera Replacement, Front and Rear Facing Cameras: paso 4, imagen 1 de 1
    • The cameras are connected together via a small ribbon cable with one electrical connection in between them.
    • Locate the small grey connector near the top of the device. Using the Spudger tool, gently pull it away from the device until it releases its connection.
    • This will come out very easily so don't use much force.
  5. HP 7 Plus 1302 Camera Replacement: paso 5, imagen 1 de 2 HP 7 Plus 1302 Camera Replacement: paso 5, imagen 2 de 2
    • Next move to front facing camera. Using the plastic spudger, push the small tabs out of the way while lightly pulling up on the camera.
    • There is a tab on either side of the camera that must both be released.
    • Then gently pull the camera up and away from the device.
  6. HP 7 Plus 1302 Camera Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • The rear facing camera is held down with double sided tape.
    • Using the tweezers, gently pry the rear facing camera up out of its socket.
  7. HP 7 Plus 1302 Camera Replacement: paso 7, imagen 1 de 1
    • Lift the camera assembly away from the device to remove it.
Conclusión
Una persona más ha completado esta guía.
Erik Hegg
Miembro Desde 07/09/15
224 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-2, Renguette SU 2015 Miembro de IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 331
