Saltar al contenido principal
HP 7 Plus 1302 Back Cover Replacement
Qué necesitas
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: paso 2, imagen 1 de 2 HP 7 Plus 1302 Back Cover Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: paso 3, imagen 1 de 2 HP 7 Plus 1302 Back Cover Replacement: paso 3, imagen 2 de 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
Conclusión
Marquies
Miembro Desde 07/07/15
245 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-2, Renguette SU 2015 Miembro de IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,018
