Saltar al contenido principal
HP 7 PLUS 1301 Volume / Power Button Replacement
Qué necesitas
  1. HP 7 PLUS 1301 Volume / Power Button  Replacement, Volume / Power Button: paso 1, imagen 1 de 2 HP 7 PLUS 1301 Volume / Power Button  Replacement, Volume / Power Button: paso 1, imagen 2 de 2
    • Make sure the device is off and not plugged in before starting.
    • Use the T5 Torx screwdriver and remove the T5x3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Volume / Power Button  Replacement: paso 2, imagen 1 de 2 HP 7 PLUS 1301 Volume / Power Button  Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Volume / Power Button  Replacement: paso 3, imagen 1 de 2 HP 7 PLUS 1301 Volume / Power Button  Replacement: paso 3, imagen 2 de 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Volume / Power Button  Replacement: paso 4, imagen 1 de 1
    • The power and volume buttons are on the side of the device. Locate these buttons to begin the replacement process.
  5. HP 7 PLUS 1301 Volume / Power Button  Replacement: paso 5, imagen 1 de 2 HP 7 PLUS 1301 Volume / Power Button  Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Gently push out the power and volume buttons with tweezers.
Conclusión
Una persona más ha completado esta guía.
Adanna Ilori
Miembro Desde 02/05/19
301 Reputación
2 Guías creadas
Equipo
UC Davis, Team S20-G6, Lore Winter 2019 Miembro de UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 250
