Saltar al contenido principal
HP 7 PLUS 1301 Battery Replacement
Qué necesitas
  1. HP 7 PLUS 1301 Battery Replacement, Battery: paso 1, imagen 1 de 2 HP 7 PLUS 1301 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the device is off and not plugged in before starting.
    • Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
  2. HP 7 PLUS 1301 Battery Replacement: paso 2, imagen 1 de 2 HP 7 PLUS 1301 Battery Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Battery Replacement: paso 3, imagen 1 de 2 HP 7 PLUS 1301 Battery Replacement: paso 3, imagen 2 de 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Battery Replacement: paso 4, imagen 1 de 2 HP 7 PLUS 1301 Battery Replacement: paso 4, imagen 2 de 2
    • Push out the connector to disconnect the battery.
    • Move the battery connector clear of the connector socket.
  5. HP 7 PLUS 1301 Battery Replacement: paso 5, imagen 1 de 1
    • Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
Conclusión
Una persona más ha completado esta guía.
Adanna Ilori
Miembro Desde 02/05/19
301 Reputación
2 Guías creadas
Equipo
UC Davis, Team S20-G6, Lore Winter 2019 Miembro de UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 17
Todo El Tiempo: 740
