Saltar al contenido principal
HP 15-f004dx RAM Replacement
Qué necesitas
  1. HP 15-f004dx RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Flip laptop over to the back, so that the stickers are showing and the RAM panel is facing up.
  2. HP 15-f004dx RAM Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the two 2mm RAM shield screws from the bottom of the laptop.
  3. HP 15-f004dx RAM Replacement: paso 3, imagen 1 de 3 HP 15-f004dx RAM Replacement: paso 3, imagen 2 de 3 HP 15-f004dx RAM Replacement: paso 3, imagen 3 de 3
    • Remove the RAM shield.
    • Small brackets secure the RAM. Push the brackets to the side to free the RAM.
  4. HP 15-f004dx RAM Replacement: paso 4, imagen 1 de 2 HP 15-f004dx RAM Replacement: paso 4, imagen 2 de 2
    • The RAM card should now pop up out of its slot. Remove the RAM.
    • Next, you will replace/reseat the memory modules following steps 3 and 4 in reverse. Once you have completed that, you can now power on the computer to test and see if reseating/replacing the RAM has resolved the problem.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 723
