Introducción
This guide will show you how to replace your optical drive. The optical drive is how your HP laptop will read and burn optical CD disks. If you are unsure if your optical drive needs to be fixed, consult the troubleshooting page here
Qué necesitas
After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
Use a J1 or PH1 screwdriver to remove the 6.5mm screw that secures the optical drive.
