Introducción
Here is a step by step way to remove and replace your battery for the HP 15-f004dx. Please make sure that you have tested the battery following the instructions listed here under Testing the Battery.
If your battery fails the tests and needs to be replaced, you are able to purchase a new battery here once you are able to identify the correct battery for your specific computer model.
Qué necesitas
After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
