Saltar al contenido principal
HP 15-f004dx Battery Replacement
Qué necesitas
  1. HP 15-f004dx Battery Replacement, Battery: paso 1, imagen 1 de 1
    • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
  2. HP 15-f004dx Battery Replacement: paso 2, imagen 1 de 2 HP 15-f004dx Battery Replacement: paso 2, imagen 2 de 2
    • Locate a switch in the upper left corner with a lock symbol next to it.
    • Slide the switch to the right until you see an unlocked symbol on the opposite side.
  3. HP 15-f004dx Battery Replacement: paso 3, imagen 1 de 2 HP 15-f004dx Battery Replacement: paso 3, imagen 2 de 2
    • There is another switch on the opposite side of the computer with a battery symbol next to it.
    • Slide this switch to the left and the battery should detach from the computer.
    • To completely remove the battery, simply pull the battery away from the computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 332
