Saltar al contenido principal
HP 15-ba0709dx RAM Replacement
Qué necesitas
  1. HP 15-ba0709dx RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx RAM Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx RAM Replacement, Back Cover: paso 3, imagen 1 de 1
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx RAM Replacement: paso 4, imagen 1 de 1
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx RAM Replacement: paso 5, imagen 1 de 1
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx RAM Replacement: paso 6, imagen 1 de 2 HP 15-ba0709dx RAM Replacement: paso 6, imagen 2 de 2
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx RAM Replacement: paso 7, imagen 1 de 1
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx RAM Replacement: paso 8, imagen 1 de 2 HP 15-ba0709dx RAM Replacement: paso 8, imagen 2 de 2
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
  9. HP 15-ba0709dx RAM Replacement, RAM: paso 9, imagen 1 de 1
    • Ensure your computer is shut down.
    • Remove any power adapters and cords connected to the laptop body.
    • Turn the computer over so the bottom is facing up.
    • Follow our guide on how to remove the backcover.
  10. HP 15-ba0709dx RAM Replacement: paso 10, imagen 1 de 1
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
  11. HP 15-ba0709dx RAM Replacement: paso 11, imagen 1 de 2 HP 15-ba0709dx RAM Replacement: paso 11, imagen 2 de 2
    • Once the module is released, gently pull the module upwards.
Conclusión
2 personas más completaron esta guía.
Reece Marr
Miembro Desde 03/20/17
369 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 700
