Saltar al contenido principal
HP 15-ay114cy Battery Replacement
  1. HP 15-ay114cy Battery Replacement, Orient the Laptop: paso 1, imagen 1 de 1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Battery Replacement, Push out the Battery: paso 2, imagen 1 de 2 HP 15-ay114cy Battery Replacement, Push out the Battery: paso 2, imagen 2 de 2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Battery Replacement, Remove the Battery: paso 3, imagen 1 de 2 HP 15-ay114cy Battery Replacement, Remove the Battery: paso 3, imagen 2 de 2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
Conclusión
Equipo
S20S3G#1 Miembro de S20S3G#1
Local Repair Groups
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 309
