Saltar al contenido principal
HP 15-ay078nr Battery Replacement
  1. HP 15-ay078nr Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr Battery Replacement: paso 2, imagen 1 de 2 HP 15-ay078nr Battery Replacement: paso 2, imagen 2 de 2
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr Battery Replacement: paso 3, imagen 1 de 2 HP 15-ay078nr Battery Replacement: paso 3, imagen 2 de 2
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
Conclusión
After installing the replacement battery, connect the device to a power source. The battery will not have a prior charge.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cameron Duffy
Miembro Desde 10/25/21
327 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 160
