Saltar al contenido principal
HP 15-ay052nr Screen Replacement
Qué necesitas
  1. HP 15-ay052nr Screen Replacement, Battery: paso 1, imagen 1 de 1
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr Screen Replacement: paso 2, imagen 1 de 1
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr Screen Replacement: paso 3, imagen 1 de 1
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr Screen Replacement, Bottom Cover: paso 4, imagen 1 de 1
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr Screen Replacement: paso 5, imagen 1 de 1
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr Screen Replacement: paso 6, imagen 1 de 1
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr Screen Replacement: paso 7, imagen 1 de 1
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr Screen Replacement, Fan: paso 8, imagen 1 de 1
    • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
    • The base is the side by the heatsink, which is made of copper.
  9. HP 15-ay052nr Screen Replacement: paso 9, imagen 1 de 1
    • Unplug the fan cable from the motherboard.
    • The fan can now be removed.
  10. HP 15-ay052nr Screen Replacement, Screen: paso 10, imagen 1 de 1
    • Disconnect the display cable.
  11. HP 15-ay052nr Screen Replacement: paso 11, imagen 1 de 1
    • Unplug the wire attached to the wireless adapter.
  12. HP 15-ay052nr Screen Replacement: paso 12, imagen 1 de 1
    • Remove the two 6.5-mm screws from the fan side of the computer.
  13. HP 15-ay052nr Screen Replacement: paso 13, imagen 1 de 1
    • Remove the two 3mm JIS #0 screws.
    • Remove the one broad head 2mm JIS #0 screw.
  14. HP 15-ay052nr Screen Replacement: paso 14, imagen 1 de 1
    • Lay the display with its back on a flat surface.
  15. HP 15-ay052nr Screen Replacement: paso 15, imagen 1 de 1
    • Pry open the screen cover using an iFixit opening tool around the entire screen.
  16. HP 15-ay052nr Screen Replacement: paso 16, imagen 1 de 1
    • Remove the four 3-mm JIS #0 screws.
  17. HP 15-ay052nr Screen Replacement: paso 17, imagen 1 de 1
    • Unplug the cable connected to the screen located on the bottom.
    • The screen should come off and can be replaced.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 388
