Introducción
Use this guide to replace the battery of your HP 14-dq0051dx laptop. Replacing the battery may be required if the battery is damaged or not functional.
Before beginning this repair, turn your laptop off and unplug from the AC adapter.
If the battery is visibly damaged or swollen, use extreme caution, and follow this guide for further help and safety information.
Qué necesitas
Turn the laptop upside down so the backside is facing up.
Use a Phillips #1 screwdriver to remove eight screws from the back case.
Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
Remove the battery from the laptop.
