Saltar al contenido principal
Google Pixelbook Go Battery Replacement
Qué necesitas
  1. Google Pixelbook Go Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Google Pixelbook Go Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Battery Replacement: paso 2, imagen 1 de 2 Google Pixelbook Go Battery Replacement: paso 2, imagen 2 de 2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Battery Replacement: paso 3, imagen 1 de 3 Google Pixelbook Go Battery Replacement: paso 3, imagen 2 de 3 Google Pixelbook Go Battery Replacement: paso 3, imagen 3 de 3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Battery Replacement: paso 4, imagen 1 de 1
    • Insert wisdom here.
  5. Google Pixelbook Go Battery Replacement, Battery: paso 5, imagen 1 de 1
    • If your replacement battery comes with a new cover already attached, disregard this step.
    • Use an iFixit opening tool to peel back the adhesive on the entire battery system.
    • Carefully remove battery from the base.
    • Align the new battery system with the cover and attach using adhesive or double-sided tape.
Conclusión
Caroline Gilliard
Miembro Desde 03/01/23
81 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 37
Ultimos 30 días: 176
Todo El Tiempo: 1,935
