Introducción
If your phone's charging port is damaged, use this guide to replace your Google Pixel XL's charging assembly.
Please note, the charging port is soldered onto the daughterboard. This guide instructs for the replacement of the entire daughterboard for simplicity, but you do have the option of replacing just the charging port.
Qué necesitas
Using a T5 Torx screwdriver, unscrew the two 3 mm screws from the daughterboard.
Casi Terminas!
Conclusión
