Saltar al contenido principal
Google Pixel 2 Rear Camera Lens Glass Replacement
Qué necesitas
  1. Google Pixel 2 Rear Camera Lens Glass Replacement, Rear Camera Lens Glass: paso 1, imagen 1 de 1
    • Blow dry the broken or scratched rear lens glass until it is a little bit too hot to touch.
    • In this process, the adhesive attaching the lens to the lens frame is melted enough so the lens is easier to remove.
  2. Google Pixel 2 Rear Camera Lens Glass Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Take extra caution when using sharp tools near the lens; if it gets damaged, the camera might have problems with auto-focusing.
    • Remove the broken/scratched glass using a pair of tweezers.
    • Use a blow dryer to remove dust and tiny pieces of broken glass.
  3. Google Pixel 2 Rear Camera Lens Glass Replacement: paso 3, imagen 1 de 1
    • Remove adhesive from the ledge of the lens frame using a pair of tweezers.
    • The adhesive needs to be removed so the clear silicone waterproof sealant will stick to the edges. Make sure to remove as much adhesive as you can, and be careful not to scratch the lens.
  4. Google Pixel 2 Rear Camera Lens Glass Replacement: paso 4, imagen 1 de 1
    • Apply the clear silicone waterproof sealant after the lens frame is neat and clean.
    • Use a wooden toothpick to gently apply the silicone sealant to the ledges of the inside shelf of the lens frame.
    • The sealant does not dry quickly, so take your time applying the silicone evenly around the edges.
  5. Google Pixel 2 Rear Camera Lens Glass Replacement: paso 5, imagen 1 de 1
    • Place the new rear lens glass on the lens frame using a pair of tweezers.
    • Make sure that the glassy side is facing outward. Place it firmly but gently.
    • It takes about five minutes for the silicone to stick and about 24 hours to fully dry.
  6. Google Pixel 2 Rear Camera Lens Glass Replacement: paso 6, imagen 1 de 1
    • Be careful not to press too much.
    • Remove excess silicone from the edges using alcohol wipes. Make sure the lens is leveled evenly and flat.
    • Do not use your phone for about two hours. For best possible results, leave it for about 24 hours.
Conclusión
The Google Pixel 2 rear camera glass replacement is a difficult task to do and being extra careful is a must or lens can be damaged.
Una persona más ha completado esta guía.
Micah Tanjay
Miembro Desde 09/20/20
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 40
Todo El Tiempo: 2,789
