Saltar al contenido principal
GermGuardian AC4825E UV-C Bulb Replacement
Qué necesitas
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: paso 1, imagen 1 de 1
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: paso 2, imagen 1 de 2 GermGuardian AC4825E UV-C Bulb Replacement: paso 2, imagen 2 de 2
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: paso 3, imagen 1 de 3 GermGuardian AC4825E UV-C Bulb Replacement: paso 3, imagen 2 de 3 GermGuardian AC4825E UV-C Bulb Replacement: paso 3, imagen 3 de 3
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: paso 4, imagen 1 de 1
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: paso 5, imagen 1 de 3 GermGuardian AC4825E UV-C Bulb Replacement: paso 5, imagen 2 de 3 GermGuardian AC4825E UV-C Bulb Replacement: paso 5, imagen 3 de 3
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
Conclusión
Una persona más ha completado esta guía.
Tim Lourenco
Miembro Desde 03/28/22
305 Reputación
2 Guías creadas
Equipo
Un comentario
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 81
Todo El Tiempo: 1,742
