Saltar al contenido principal
Garmin inReach Explorer Plus Antenna Replacement
Qué necesitas
  1. Garmin inReach Explorer Plus Antenna Replacement, Battery: paso 1, imagen 1 de 1
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus Antenna Replacement: paso 2, imagen 1 de 1
    • Remove the back cover.
  3. Garmin inReach Explorer Plus Antenna Replacement: paso 3, imagen 1 de 2 Garmin inReach Explorer Plus Antenna Replacement: paso 3, imagen 2 de 2
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus Antenna Replacement, Motherboard: paso 4, imagen 1 de 2 Garmin inReach Explorer Plus Antenna Replacement, Motherboard: paso 4, imagen 2 de 2
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus Antenna Replacement: paso 5, imagen 1 de 2 Garmin inReach Explorer Plus Antenna Replacement: paso 5, imagen 2 de 2
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus Antenna Replacement: paso 6, imagen 1 de 2 Garmin inReach Explorer Plus Antenna Replacement: paso 6, imagen 2 de 2
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus Antenna Replacement: paso 7, imagen 1 de 3 Garmin inReach Explorer Plus Antenna Replacement: paso 7, imagen 2 de 3 Garmin inReach Explorer Plus Antenna Replacement: paso 7, imagen 3 de 3
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus Antenna Replacement, LCD Screen: paso 8, imagen 1 de 2 Garmin inReach Explorer Plus Antenna Replacement, LCD Screen: paso 8, imagen 2 de 2
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
  9. Garmin inReach Explorer Plus Antenna Replacement: paso 9, imagen 1 de 3 Garmin inReach Explorer Plus Antenna Replacement: paso 9, imagen 2 de 3 Garmin inReach Explorer Plus Antenna Replacement: paso 9, imagen 3 de 3
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
  10. Garmin inReach Explorer Plus Antenna Replacement, Antenna: paso 10, imagen 1 de 3 Garmin inReach Explorer Plus Antenna Replacement, Antenna: paso 10, imagen 2 de 3 Garmin inReach Explorer Plus Antenna Replacement, Antenna: paso 10, imagen 3 de 3
    • Gently pull out the antenna wire and remove the antenna from the device.
    • The antenna should now slide out easily. If the antenna is stuck, use the spudger to gently dislodge the antenna from its housing.
Conclusión
Sean Kelley
Miembro Desde 09/28/21
387 Reputación
4 Guías creadas
Equipo
Clemson, Team 5-4, Hunter Fall 2021 Miembro de Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 19
Todo El Tiempo: 431
