Saltar al contenido principal
Garmin Rino 700 Screen Replacement
Qué necesitas
  1. Garmin Rino 700 Screen Replacement, Battery Disconnect: paso 1, imagen 1 de 1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Screen Replacement: paso 2, imagen 1 de 2 Garmin Rino 700 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Screen Replacement: paso 3, imagen 1 de 2 Garmin Rino 700 Screen Replacement: paso 3, imagen 2 de 2
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Screen Replacement, Motherboard: paso 4, imagen 1 de 2 Garmin Rino 700 Screen Replacement, Motherboard: paso 4, imagen 2 de 2
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
  5. Garmin Rino 700 Screen Replacement: paso 5, imagen 1 de 3 Garmin Rino 700 Screen Replacement: paso 5, imagen 2 de 3 Garmin Rino 700 Screen Replacement: paso 5, imagen 3 de 3
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
  6. Garmin Rino 700 Screen Replacement, Screen: paso 6, imagen 1 de 3 Garmin Rino 700 Screen Replacement, Screen: paso 6, imagen 2 de 3 Garmin Rino 700 Screen Replacement, Screen: paso 6, imagen 3 de 3
    • Carefully detach the screen at the bottom connections using your hands to reveal the ribbon connection.
    • For a guide on disconnecting and reconnecting the Zero Insertion Force (ZIF) connectors, please visit this guide.
Conclusión
Abigail Dugan
Miembro Desde 09/28/21
512 Reputación
5 Guías creadas
Equipo
Clemson, Team 5-5, Hunter Fall 2021 Miembro de Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 300
