Saltar al contenido principal
Garmin Rino 700 Battery Replacement
Qué necesitas
  1. Garmin Rino 700 Battery Replacement, Battery Disconnect: paso 1, imagen 1 de 1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Battery Replacement: paso 2, imagen 1 de 2 Garmin Rino 700 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Battery Replacement: paso 3, imagen 1 de 2 Garmin Rino 700 Battery Replacement: paso 3, imagen 2 de 2
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Battery Replacement, Battery: paso 4, imagen 1 de 3 Garmin Rino 700 Battery Replacement, Battery: paso 4, imagen 2 de 3 Garmin Rino 700 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Using a Phillips #000 screwdriver, remove the two 4.8 mm screws holding the battery bracket in place.
    • Using a plastic opening tool, remove the battery from the back case of the device.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Abigail Dugan
Miembro Desde 09/28/21
512 Reputación
5 Guías creadas
Equipo
Clemson, Team 5-5, Hunter Fall 2021 Miembro de Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 1,192
