Slide the ends of the long black connector onto the sides of the pedals.
Both sides of the connection are shaped like a half-circle, so they can only connect in the proper orientation.
Ensure all the screws on the connector are pointing up. To do so, you will need to "wind" the secondary pedal up manually before attaching the connector.
Arrange the pedals in the drumkit. The primary pedal should be centered on the kick drum, while the secondary pedal should be wherever comfortable.
If necessary use the drum key to adjust the height of the beaters to be vertically centered on the kick drum.
Now tighten everything down!
6 personas más completaron esta guía.
Un Comentario
Nice to see some double bass enthusiasts on here! I am in the process of building an electronic midi drumset from piezos, some old stationary cardio equipment and an alesis dm5. The tooling, oh the tooling. Taps and dies, welding, now i need a lathe to make a double bass pedal from scratch... Www.gpsn.uspto.gov is a great resource for technical info and also creepy government technology. Ill post when i can. Peace
