Saltar al contenido principal
GI Node Installation Guide
Qué necesitas
  1. GI Node Installation Guide, Select install location: paso 1, imagen 1 de 1
    • Locate a spot in the middle of the rain garden where the soil is bear/free from plants.
    • We need to install in the middle of the rain garden to ensure quality data.
  2. GI Node Installation Guide, Auger hole for node: paso 2, imagen 1 de 2 GI Node Installation Guide, Auger hole for node: paso 2, imagen 2 de 2
    • At the selected location, use a post hole digger to make a hole for the node.
    • Take your time so as to not disturb the soil too much.
    • Use a tape measure to make sure the hole is 3 feet deep.
    • The soil removed from the hole will fill roughly 2 buckets
    • Fill the first bucket with topsoil
    • When the soil begins to look like clay, switch to filling the second bucket
  3. GI Node Installation Guide, Install GI node: paso 3, imagen 1 de 2 GI Node Installation Guide, Install GI node: paso 3, imagen 2 de 2
    • Set the GI node into the 3 ft hole.
    • Do your best to make sure it is straight in the ground.
    • Pack the topsoil from the first bucket around the node to make sure it is secure in place. You shouldn't need to use any soil from the second bucket
    • If the surrounding plants are too tall, shading the solar panel, use the shears to trim the plants.
    • Fill out the deployment form on AirTable.
    • Once installed, confirm the GI node is reporting to the internet by going to its designated website.
Linea de Meta
Brooke Mason
Miembro Desde 05/29/19
2,958 Reputación
17 Guías creadas
Equipo
Open-Storm Miembro de Open-Storm
Community
Miembros de 14
24 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 283
