Saltar al contenido principal
Fusion5 5.5 Gen II Fingerprint Sensor Replacement
Qué necesitas
  1. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Back Cover: paso 1, imagen 1 de 2 Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Back Cover: paso 1, imagen 2 de 2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Midframe: paso 2, imagen 1 de 2 Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Midframe: paso 2, imagen 2 de 2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Fingerprint Sensor Replacement: paso 3, imagen 1 de 2 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: paso 3, imagen 2 de 2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Fingerprint Sensor: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
  5. Fusion5 5.5 Gen II Fingerprint Sensor Replacement: paso 5, imagen 1 de 3 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: paso 5, imagen 2 de 3 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: paso 5, imagen 3 de 3
    • Using the tweezers, grab the ribbon cable and pull it out from its connector.
    • Remove the fingerprint sensor from its socket on the motherboard.
    • When re-installing the fingerprint sensor, make sure to align the ribbon cable with the plastic socket on the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 253
