Saltar al contenido principal
Fujifilm FinePix XP50 Rear Case Replacement
Qué necesitas
  1. Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: paso 1, imagen 1 de 3 Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: paso 1, imagen 2 de 3 Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: paso 1, imagen 3 de 3
    • Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
    • Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm FinePix XP50 Rear Case Replacement: paso 2, imagen 1 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 2, imagen 2 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 2, imagen 3 de 3
    • Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
    • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm FinePix XP50 Rear Case Replacement: paso 3, imagen 1 de 1
    • Using Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm FinePix XP50 Rear Case Replacement: paso 4, imagen 1 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 4, imagen 2 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 4, imagen 3 de 3
    • Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
    • Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm FinePix XP50 Rear Case Replacement: paso 5, imagen 1 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 5, imagen 2 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 5, imagen 3 de 3
  6. Fujifilm FinePix XP50 Rear Case Replacement: paso 6, imagen 1 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 6, imagen 2 de 3 Fujifilm FinePix XP50 Rear Case Replacement: paso 6, imagen 3 de 3
    • Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
Conclusión
Una persona más ha completado esta guía.
Paulo Abalos
Miembro Desde 03/20/15
122 Reputación
1 Guía escrita
Equipo
Baylor, Team 2-4, Grigsby Spring 2015 Miembro de Baylor, Team 2-4, Grigsby Spring 2015
BU-GRIGSBY-S15S2G4
4 Miembros
8 Guías creadas
Un comentario
where can I buy the Fujifilm FinePix XP50 Rear Case?
CO - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 776
