Introducción
Use this guide to replace the Input Cover on your Framework laptop.
You'll only need a T5 bit screwdriver and a replacement Input Cover for this guide. Note: The Framework laptop comes with a screwdriver with a T5 bit and a spudger.
Qué necesitas
Shut down the laptop and unplug the power cable if it is plugged in.
Close the laptop lid and place it upside down.
Locate the five T5 bits underneath the laptop. Using a screwdriver with a T5 bit, unscrew the five screws on the bottom cover.
The screw on the bottom left will not unscrew as far. This screw lifts the input cover slightly.
Flip the laptop over and open the lid.
The bottom right corner of the input cover should have lifted up to reveal a small gap which can be used to remove the input cover.
Carefully lift the input cover up from the bottom right corner using your finger or a pry tool. The input cover should be only held in place with magnets.
Locate the large black cable on the right side connecting the touchpad to the mainboard.
On the mainboard side of the cable, there is a large loop with a orange spot. Insert your finger through the loop and pull up.
You can now safely remove the input cover from the laptop.
Remember to connect the new touchpad cable to the mainboard before placing the new input cover on the laptop.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Framework Laptop 13 answers community for help.
Una persona más ha completado esta guía.
