Saltar al contenido principal
Flipper Zero Button Replacement
Qué necesitas
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero Button Replacement, Remove the microSD card: paso 2, imagen 1 de 1
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero Button Replacement, Remove the screws: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero Button Replacement, Open the back cover: paso 4, imagen 1 de 3 Flipper Zero Button Replacement, Open the back cover: paso 4, imagen 2 de 3 Flipper Zero Button Replacement, Open the back cover: paso 4, imagen 3 de 3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero Button Replacement, Seperate the chassis from the top cover: paso 5, imagen 1 de 2 Flipper Zero Button Replacement, Seperate the chassis from the top cover: paso 5, imagen 2 de 2
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero Button Replacement, Disconnect the battery: paso 6, imagen 1 de 1
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero Button Replacement, Disconnect the ribbon cable: paso 7, imagen 1 de 1
    iFixit Opening Picks (Set of 6)
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero Button Replacement, Release the battery chassis: paso 8, imagen 1 de 2 Flipper Zero Button Replacement, Release the battery chassis: paso 8, imagen 2 de 2
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
  8. Flipper Zero Button Replacement, Remove the ribbon cable: paso 9, imagen 1 de 2 Flipper Zero Button Replacement, Remove the ribbon cable: paso 9, imagen 2 de 2
    • Use a plastic pick to lift the latch up to unlock the connector and carefully remove the ribbon cable.
  9. Flipper Zero Button Replacement, Unscrew the the button chassis: paso 10, imagen 1 de 1
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  10. Flipper Zero Button Replacement, Seperate the button chassis: paso 11, imagen 1 de 3 Flipper Zero Button Replacement, Seperate the button chassis: paso 11, imagen 2 de 3 Flipper Zero Button Replacement, Seperate the button chassis: paso 11, imagen 3 de 3
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
  11. Flipper Zero Button Replacement, The button layout: paso 12, imagen 1 de 1
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad).
  12. Flipper Zero Button Replacement, Unlatching the buttons: paso 13, imagen 1 de 1
    Flathead 1.5 mm Screwdriver
    $5.49
  13. Flipper Zero Button Replacement, Remove the light diffuser: paso 14, imagen 1 de 3 Flipper Zero Button Replacement, Remove the light diffuser: paso 14, imagen 2 de 3 Flipper Zero Button Replacement, Remove the light diffuser: paso 14, imagen 3 de 3
    • Use a flat head screwdriver to release the light diffuser from the chassis and pull it out.
Conclusión
Sebastian
Miembro Desde 08/19/18
31,061 Reputación
71 Guías creadas
2Guía Comentarios
I don't believe the top buttons on the plastic top layer are the problem. It's the physical button underneath the circuitboard.
Nutcheese99 - Contestar
ifixit screwdrivers are too big for step 3 you must use wera PH0 or similar size
Aeris (AZ) - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 73
Todo El Tiempo: 3,565
